1JZ Intake Manifold Question!
Hi, I have a 1JZGTE that I'm putting together and had a hard time finding bolts/nuts for the intake manifold. Anyone know the size bolts for the intake manifold-adapter plate-head. I need those bolts and the double threaded bolt that mounts on the head. Also need to know what I use to mount the fuel rail to the intake manifold adapter plate. If anyone has spare I would be glad to buy them off of you.
fuel rail bolts that clamp down those stupid plates are 10mm i think. if you dont have the plates just make some real quick. the 2jz ones have different bolt hole locations im pretty sure
I took the time to create an account here just to say, you are wrong on the bolts. I ordered the ones you have listed ($20 waste) turns out you are a number off. It's 90105-08254!!!
