timing belt scooting itself off
Old 12-02-12, 06:56 PM
sj408
sj408's Avatar
Default timing belt scooting itself off
hey guys, was messing around under the hood an noticed my timing belt is starting to slip itself off the cam gears, this worries me as i just re assembled the engine a very short time ago.
Anyone know whats causes this? could it be a bad tensioner? its only got like 30k on it.
Old 12-02-12, 08:43 PM
95SC3T
95SC3T's Avatar
when you reassembled the motor, did you reuse the old tensioner? If so i would advise you to go change that and new belt. Check all pullys for wear and breakage while in there.
Old 12-02-12, 09:10 PM
sj408
sj408's Avatar
Tensioner had MAYBE 30k on it brand new from toyota, I guess ill have to take it off and replace them??
Old 12-02-12, 09:34 PM
xspsi6
xspsi6's Avatar
He is talking about the Hydro tensioner not the idler pullys.
Old 12-02-12, 09:35 PM
xspsi6
xspsi6's Avatar
Also how did you compress it?
Old 12-02-12, 11:50 PM
sj408
sj408's Avatar
yeah that as well, i forgot how we did it. Think we used a clamp or something. did i mess it up?
Old 12-03-12, 04:53 AM
lexforlife
lexforlife's Avatar
when you say you just reassembled the motor , was the timing cog removed and reinstalled . if the timing cog is not 100% on it will produce the results you describe . i use a huge socket the size of the cog and knock it on evenly and squarely to ensure its 100% on .
Old 12-03-12, 02:48 PM
sj408
sj408's Avatar
Sorry for seeming less than informed, whats the timing cog? got a pic?ill tear it down and see right now
Old 12-03-12, 03:26 PM
sj408
sj408's Avatar
UPDATE: so guys, i just watched the cam gears while it idled for a few seconds and i dont know if my eyes are playing tricks on me but it lookes as if the exhaust cam gear is wobbly.
and again... what is the timing cog?
Old 12-03-12, 03:47 PM
lexforlife
lexforlife's Avatar
this is the timing cog with the reluctor wheel , if its not 100% on and even it will cause the belt to misalign with cam gears
Old 12-03-12, 03:50 PM
sj408
sj408's Avatar
O, that looks like the cam gear right? So take em off and re seat them?
that must be why one looks "wobbly" right?
Old 12-03-12, 03:52 PM
lexforlife
lexforlife's Avatar
no this cog mounts onto the snout of the crank behind the crank pulley itself .. if motor was rebuilt , this would have been removed
Old 12-03-12, 04:06 PM
sj408
sj408's Avatar
interesting, and these are the type of symptoms id see huh?? would it make the cam gear look wavy?
Old 12-03-12, 04:16 PM
lexforlife
lexforlife's Avatar
yes , if gog is not 100%on the snount , it will not line the belt up with the cam gears and the belt will walk off ..came gears tend to be alittle wobbly as ive seen that from time to time .. if its excessive then you have something else going on
Old 12-03-12, 07:34 PM
sj408
sj408's Avatar
so i got it all ripped down in about a half an hour and turns out the nut on the tensioner pulley was gone, pretty much the only thing keeping the belt on was the dang plastic cover haha
mooseboy84
10-31-15 11:35 PM
tedsterb
12-02-14 09:23 PM
Chuckinnj
05-11-14 08:29 PM
kaotiq
24
03-18-05 07:23 AM
GSquicksilver
Maintenance
05-16-02 07:23 PM
Quick Reply: timing belt scooting itself off
