1jz swap ecu options
Old 10-10-12, 03:48 PM
murph4747
murph4747's Avatar
Default 1jz swap ecu options
hi I'm done with my 1jz swap but i my last item is i need a ecu, i got my harness wired to run a 2jzgte ecu, now I'm looking for a ecu, iv come across one thats for sale around me that has been chipped, would this cause a issue since I'm running a 1jz, the 1jz is bone stock besides a down pipe and new plugs and fluids
Old 10-12-12, 07:14 PM
murph4747
murph4747's Avatar
anyone? bump........
Old 10-12-12, 07:20 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
If you have the harness wired correctly i dont see any problem in using the 2jzgte, but i am no expert by any means. Why did you do this instead of using what was factory and using a piggyback or just bought a DM AEM V2 with the correct patch harness? Or maybe a Haltech or ProEFi?? I maybe confused...
Old 10-13-12, 01:58 PM
TweakTech
TweakTech's Avatar
As long as the harness is correctly wired for a 2JZ sequential injection, versus a 1JZ's batch injection, you can run any 2JZGTE ECU, unless you go full EMS, then batch/sequential makes no difference. Your tuner will take care of the outputs for that when they tune the car.
Old 10-18-12, 04:49 PM
murph4747
murph4747's Avatar
thank you guys, i ended up getting a stock 2jzgte ecu and I'm working on getting the car running right now (low fuel pressure) everything seems to be working right with the ecu, I'm getting power to the injectors and ignition so hopefully it works out
Old 10-18-12, 04:53 PM
murph4747
murph4747's Avatar
and i chose this route because the harness that came with my engine was chewed up bad, so i had the stock harness wired for coils and the right injectors, and so i don't have to deal with the common failure of 1jz ecus and i now have the option if i wanna go 2jzgte i can just swap the harness and i don't have to go through wiring again
StuntKing
SC400 / 300 Classifieds
06-16-15 07:32 PM
2jzinsider
SC- 1st Gen (1992-2000)
12-26-13 10:39 AM
Sk8tehwake
05-15-12 11:18 AM
Quick Reply: 1jz swap ecu options
