Single turbo guys
Old 08-30-12, 10:04 AM
dawizone
dawizone's Avatar
Default Single turbo guys
Quick question... How far you guys travel on your mid to large size single turbo SC's... The bay gets so hot on my 6265 gte with turbo blanket that i can't imagine taking it on a drive for longer then an hour or so... What are your thoughts and experience with this?
Old 08-30-12, 10:08 AM
DRFT103
DRFT103's Avatar
You're good bro. Turbos get really hot, it's natural. after an hour of driving if something doesn't melt by then it's not going to. I wouldn't worry too much at all.
Old 08-30-12, 10:36 AM
99SC42
gte & na-t
99SC42's Avatar
Haha Welcome to the FI world lol , get some heat insulator and insulate your trans tunnel that will help alot.
Old 08-30-12, 01:12 PM
Ali SC3
Ali SC3's Avatar
I find it gets up to a really hot point and pretty much stays there, never really gets to anything dangerous but the bay is much better with a turbo blanket than without. try wrapping your DP and runners if you haven't done so already.
Old 08-30-12, 10:43 PM
dawizone
dawizone's Avatar
Thanks guys
Old 08-31-12, 08:12 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Mine still has the factory black insulation on the firewall. As of right now, it is still good and holding up well, even when the AC is blowing on low at 72 degrees. I also have a turbo blanket and my DP is also wrapped in DEI wrap.
Old 08-31-12, 08:21 AM
blk&blu*j
blk&blu*j's Avatar
I run a large frame Turbo 74mm/1.25 rear and I commonly drive 5-6 hrs with no issues.
Coated DP, mani, and turbo blanket.
Old 08-31-12, 02:52 PM
Halon
Halon's Avatar
I've driven mine of 4hr road trips up to Fargo and back several times. No turbo blanket. Never had an issue.
Old 09-02-12, 01:12 PM
N1T3MARE
N1T3MARE's Avatar
Driven my 76mm Supra to Charlotte and back in the same day. (4 hours there and 4 hours back home). No problem at all. My manifold, turbine housing, and downpipe are ceramic coated. The downpipe is wrapped and the turbine housing has a blanket also.
Studiogeek
08-26-15 03:11 PM
kleen1JZSC
24
03-10-10 07:10 PM
yauser
07-30-08 07:19 PM
HI98GS
Performance
08-20-06 08:41 AM
indypwr
02-24-04 08:45 AM
Quick Reply: Single turbo guys
