Brian Crower 1jz 264 camshaft results.
Old 11-10-13, 04:39 PM
  #76
Blakenz
Blakenz's Avatar
The T60 equipped car has since been re dynoed with the following mods, LINK G4 Xtreme computer, bigger fuel system, Chinese inlet plenum(poorly made, needed lots of corrective work to make it acceptable).
It yielded 453hp to the wheels. Note boost was increased from 16psi to 20 psi.
Old 06-14-14, 03:05 AM
  #77
Blakenz
Blakenz's Avatar
here is an update on my latest effort in pushing the stock CT12A turbo envelope.
The rear turbo has been reversed, allowing 3 inch intakes, and 3" down pipes for each turbo. Each turbo has a bellmouth bolted on the front.Car is very responsive. Currently around 370hp at wheels, with no boost controller or such, on mild timing on 98 octane RON. The exhaust is 3.5". A narrower radiator allows very short intercooler plumbing, with the 4" thick intercooler core mounted where the stock radiator used to be. Bigger injectors and fuel pump to go in next. Cams still to come.
PHOTO BELOW.
Old 06-14-14, 03:12 AM
  #78
Blakenz
Blakenz's Avatar
upload?https://www.clublexus.com/forums/att...1&d=1402740592
Old 06-14-14, 07:45 AM
  #79
INTIMAZY
INTIMAZY's Avatar
Whoa.... very cool.
Old 06-26-14, 11:19 PM
  #80
Blakenz
Blakenz's Avatar
An update.
The car was on the dyno today,with its E85 fuel system(top feed rail, ID1000s, DW300 fuel pump,Aeromotive fuel filter), and delivered 348whp at 4000rpm , but then flatlined from there on.
Then it started losing boost, dropping to 19psi, then 17psi. So it turns out the gaskets between the turbos and the turbo manifold are leaking/blown out. So this will need to be rectified(read $$$$ labour)It is possible this blow out was caused by the flanges (on the manifolds)being slightly warped.
The flatlining power was a mystery, until the tuner spotted a damaged cam angle sensor/plug. With a temporary fix, he pushed it back on , and the car ran 390whp at 20 psi, with the aforementioned (pre turbo)exhaust leak.
So the power is looking OK at this stage.
I have since found out the timing (at the top end) was kept low, due to the exhaust leak, so with proper E85 timing wound in, we could easily be looking at 405-415 whp.
I intend to put cams in soon.
Old 07-15-14, 02:56 AM
  #81
Blakenz
Blakenz's Avatar
UPDATE.
well the soarer went on the dyno today. Stock turbos, stock cams. Power FC. E85 fuel.
At 21 psi, it made 435hp. peak torque is at approx 3900rpm, and has 348hp by then, so it should be a lot of fun to drive. It is hitting 20 psi by around 3550rpm.
At 22 psi, it lost a fraction of power.
at 25psi it dropped to 418hp or so.
so clearly the turbos are out of efficiency, so i will no longer pursue the high boost route(was aiming for 25psi or more)
Old 07-17-14, 10:44 AM
  #82
kez
kez's Avatar
Wow a lot of work there. Very nice numbers too
Old 07-26-14, 08:54 PM
  #83
emoFTW
emoFTW's Avatar
That's interesting information! Props to you!
Old 01-03-15, 02:22 PM
  #84
Blakenz
Blakenz's Avatar
update. Recently my 'stock turbo' E85 soarer ran 11.9 sec at 116mph, but seemed to be suffering heat soak.
so i paid attention to under bonnet temps, (and reduced weight by 100 pounds) and the car ran much faster yesterday, doing 11.516sec@121.9 mph. Very pleased.
Old 01-06-15, 09:06 AM
  #85
jkpgt96
jkpgt96's Avatar
Wow, that is cookin' on stock twins!
Old 01-06-15, 07:45 PM
  #86
Ali SC3
Ali SC3's Avatar
thats pretty neat to flip it around like that, never seen that one before. wonder how it would do on a 2jz on us twins like that. any more info on the downpipe for the rear turbo?
Old 01-06-15, 11:47 PM
  #87
Blakenz
Blakenz's Avatar
send me you email address,Ali, and i'll email you some photos that will interest you, and perhaps post them up here, as they will answer your questions.
Old 01-07-15, 01:56 PM
  #88
Ali SC3
Ali SC3's Avatar
just post them up here if you can. always good to see new ways to do things.
Old 01-08-15, 12:11 AM
  #89
Blakenz
Blakenz's Avatar
Sorry,I'm not very computer literate, and struggle to post images that aren't on my hard drive.
Old 09-09-15, 06:00 AM
  #90
megamax
megamax's Avatar
you have a pic of said intake? I have the same one iam betting..
Quick Reply: Brian Crower 1jz 264 camshaft results.
