a/c problems
a/c problems
so i just bought a 92 sc300 and its not blowing cold air. i bought a r-134a rechargable freon but i heard my car needs to use r-12 freon which isnt sold anymore to the public. Does anybody know if it will make a difference is i use r-134a? i really dont want to take it to a shop.
Thanks guys
Thanks guys
Fix it Right or Mickey Mouse it. Its up to you
You must take it to a shop to evacuate (suck out all the old crap) and refill to the right pressure with the R134a. Those kits they sell at auto parts stores do not work in my experience. Those are made for if you are already running on R134a. They will also inject a die into your system to check for leaks. You take it back after running the ac for a couple weeks and the will check it with a black light to catch any leaking.
Thanks guys
Thanks guys
If you don't want to take it to a shop you need to diagnose the problem step by step.The first thing you want to do is check the fuses, especially the 10 amp fuse (red) under where your left shin would be while sitting in the car with your leg straightened out toward the firewall. It's hidden with carpet. Just pull back the carpet and you will see a small rectangular black box. Take the lid off and there it is. The fuse is toward the upper left area. It is actually called the HTR fuse on the diagram I think. I will check in a few hours. I need to leave now.
Pep Boys Warning
I took my SC in for a FREE brake check to Pep Boys and they squirted some oil on my shocks to say they were leaking. Watch out for those FREE anything form auto mechanics.
The evacuation and refill should be left to a professional or a DIY'er that has the right equipment. The evacuation process sucks everything out of the system, including any moisture. Moisture is poison to an ac setup.
Official R12 to R134a Retrofit
Here is the Service Bulletin from Lexus on how to change from R12 the correct way. My mechanic charged me less than $100,00 for everything. AC is ice cold! Best $100,00 I ever spent. lol. Oh, not to mention those kits they sell at auto parts store cost about $30.00. For the extra seventy bucks and knowing its done right, priceless.
aparker813
08-07-07 09:51 AM
