Suggestions on 440 cc injectors
Old 07-14-12, 09:39 PM
norcal2jz
norcal2jz's Avatar
Question Suggestions on 440 cc injectors
In the process of building my 95 sc3 original 5spd into NA-T
already ported the head and put in tt gaskets and ARP head studs..
in the market looking for 440cc injectors or something around that number
was looking at some denso 440cc and the price isnt too bad..any other suggestions?
Old 07-14-12, 10:16 PM
Vwpride12
Vwpride12's Avatar
440's will be too small. You should go bigger. I ran out of injector on the Dyno and it's not a good feeling. Don't go less than 1000's, with the supporting fuel pump.
Old 07-14-12, 11:23 PM
norcal2jz
norcal2jz's Avatar
This is my DD and Im really not trying to push more than 400 to the wheels ...Im looking at 550cc also thanks for the tip fuel pump is my next step
Old 03-06-13, 06:39 PM
jschru
jschru's Avatar
bumping this thread since i have the same question. I'm going na-t using an aristo 2jz-gte ecu and am looking for 440cc injectors. does anyone have any suggestions on whats available, that's drop-in for the sc300. I know i can use mk3 injectors but then I'd need to wire in the resistor box.
Old 03-06-13, 09:03 PM
jwin
jwin's Avatar
I have some brand new 550cc for sale. direct drop in for 2jzge with resistor box.
Old 03-06-13, 09:43 PM
sj408
sj408's Avatar
The lucas 440cc high impedance are cheap and work fine for me at 14psi
Old 03-06-13, 11:47 PM
jschru
jschru's Avatar
I'm using an aristo ecu so i need the 440cc injectors so i can get it running and together before i start tuning it
were they a direct fit?
Old 03-08-13, 07:03 PM
sj408
sj408's Avatar
Yes they were drop-in high impedance, and cheap too
Old 03-09-13, 10:55 AM
jschru
jschru's Avatar
thanks a bunchI just ordered a set of lucas 440cc. so close to being able to finally install everything
Kstyle55
Performance
04-03-14 01:56 PM
6SOARER
SC400 / 300 Classifieds
09-09-13 09:16 PM
elpanda
10-06-12 07:05 AM
tampa mike
04-02-09 12:58 PM
That-Guy
10-26-08 11:35 AM
Quick Reply: Suggestions on 440 cc injectors
