quick question about my swap w/pics
i just have two quick questions for the pro's out there...
Here is a picture of the alternator wiring, as you can see the alt wiring has been cut, it has been cut because the wiring from the oval plug was part of the body harness.
the problem is, on my 94, the alt wiring is a round plug and was part of the engine harness.
all I have on my car is this single alt wire. My question is.... how do I make this work?
I know everyone's answer will be to send it to dr tweak but my car is completely stripped out and all I need is a running motor, I dont have a radio, A/C or anything.. I just want a running car. my ignition, fuel pump etc will all be ran on a switch in the dash. this is my drift car.
also when i got my my motor in it looks like the TPS casing is bent a little, I'm wondering if this would give me boost leak?
I was also wanting a direct answer for the alternator issue here. I know there will be a swarm of people that say to search, but there isn't a good answer anywhere about how these wires need to be attached.
1JZ Single SC400
On my understanding, you can use the stock wiring from the car side if both plugs are the same. This is what i did and worked perfect. In your case, you have a different plug. I beleive you can just splice the wires to make it work, but it appears that you are missing some wires too. What motor is that? 1Jz or 2jz aristo or soarer? Or do you know?
It is a 94 Lexus sc300 and the motor is a chaser 1jz.
On my original motor the three alt wires are on the engine harness. On the 1jz, they came from the body harness and were cut. So now I have nowhere to wire these to. are there any shortcuts or any way to make it work?
My motor came the exact same way. The only info I've found is color coding, where the wires are *supposed* to go and their function. The info where they were supposed to go has been hard to follow and not conclusive though and it didnt make sense as to why they were cut off in the first place and not tied into the GE factory loom.
Not trying to hijack your thread for my well being here man, just trying to get some good information in one place for the community.
after the swaps i have done this is what i can tell you.
on 92-94 SC the alternator plug is part of the engine harness and it's the Round plug
on 95+ it's oval and it's part of the engine bay harness on the right side.
you might have to rewire the alternator wires those 3 wires!
and QUICKSC4, thanks for posting that, but honestly I have no idea what any of that means.
I realize I have to extend the three wires to a certain place, that part is simple. It's just a matter of figuring out where to wire them in.
I ran into the same problem after trying to put a 2jzGE motor from a 97 into this same car, and pulled the motor back out because I couldn't figure it out. but now that i paid $2750 for a 1jz/r154 setup, I have to figure this out.
anyone?
if there is a shortcut / race car like way to make it work i'm down. My only concern is that if a 94 has the wires in the engine harness, those wires must go to the ECU, and if on a 97 those wires are in the body harness, then it's getting its charge from something in the body, now if i tried to rig it up somehow in the ECU, how would the ECU read it and reconize the signal or whatever it does if it wasnt suposed to go there?
I know a lot of people might be thinking that this is the "different alt plug" issue, where you would simply cut the plug and wire in your other. that's not the case here at all.
the problem is that since the alt plug from a 94 is in the engine harness, and the alt plug from a 97 is in the body harness, while swapping in a 1jz from a 97, we are left with NO alt plugs on either harness
Those wires don't go to the ECU check the pinout above it tells where those wires go.
Y-G goes to the cluster combination meter
Middle on gors to the body plug
White wire goes to the fuse box on the driver side.
This still makes no sense to me.
is there any way you can show us exactly what to wire into, for the sake of the whole community, those who do not send their harness to dr. tweak?
