1jz swap EFI Fuse poping
Old 05-11-12, 08:06 PM
Durangosc
Durangosc's Avatar
Default 1jz swap EFI Fuse poping
I just finished my 1jzgte(from Soarer) swap into my 98 sc300. I extended all the wires and plugged everything in. First issue is as soon as I hooked up the battery the car started cranking(without key in ignition). Second is the efi fuse keeps blowing. Are there wires on the body plugs that need to be swapped? If so which ones? Thanks everyone.
Old 05-11-12, 08:08 PM
k7q
k7q's Avatar
sounds like a short if the fuse keep popping.
Old 05-11-12, 10:34 PM
INTIMAZY
INTIMAZY's Avatar
How exactly did you extend the wires? You are probably going to need to go over your connections again. Something is grounding out.
Old 05-21-12, 01:57 PM
Durangosc
Durangosc's Avatar
Traced it all down and it was a power wire grounding out. Thanks guys
Old 04-14-16, 05:23 PM
Volume123
Volume123's Avatar
A power wire where? I'm having the same issue...
x2jzsc300x
SC- 1st Gen (1992-2000)
10-14-13 03:37 PM
JDMb16bEG6
06-05-12 10:06 AM
Superjatt
07-25-11 07:01 AM
Parker Gen
04-25-09 07:01 PM
LexusTexas
04-27-08 01:57 PM
Quick Reply: 1jz swap EFI Fuse poping
