Supra rad. & universal trans. cooler
Hey, right now I'm gather parts for my manual swap, and it just so happen that my radiator in my SC300 wanted to develop a leak.
I was wondering, would it be ok for me to get a MKIV Supra 2 row radiator off ebay and run a seperate universal transmission cooler also from ebay for my automatic, while I'm gathering parts? I plan to run this for about a month or 2.
Radiator is from grayelephant on ebay for $138 shipped.
Trans. cooler would be FRAM TC6101.
Thanks.
Thanks.
Get an SC300 radiator , because it's pnp.
The supra radiator sits a little lower so you will have to modified the SC radiator holding brackets to make it work.
Just get the SC auto radiator .
Mainly went with this radiator since later on down the road I'm going NA-T or 1JZ and going 5spd also. Might aswell upgrade at the same time.
I'll update this thread once I get everything and also put up some install pics.
Just order the tt fan shroud from drift motion and your in like flint and the fan will stay away from the shroud. if you use the supra rad and the stock shroud the fan will contact the shroud.
good luck.
good luck.
