350Z trans adapter?
Old 12-15-14, 01:58 PM
  #436
estomax
estomax's Avatar
up in the lex, the wacky welded loopahoop **** i had to do was to move the shifter to the stock location for a 1jz/2jz. It might not be required for a 1UZ since it's block sits further forward. i started out with what you have in the above pictures and the shifter is about 3 inches too far back (it is in the cup holder basically behind the shift boot).
as far as ss clutch line, i just used the one from driftmotion, it is a good length and works.
  #437
UpInTheLex
UpInTheLex's Avatar
Info about the 6 speed Gearboxes from 350z. This seems like solid, reliable info.
Source: Busy Badger from NICO Club.com
"A lot of the gear grinds depends on the driver and the conditions and not the transmission itself. But there is also a difference in the transmissions from various model years. I've run up 100K on mine and I've got no grinding. My miles are 95% highway/interstate though so the lower gears don't see much use.
2003 6MT
Double cone synchronizers in 1st and 2nd
No triple cone synchronizers
2004 6MT
Double cone synchronizers in 1st, 3rd, 4th
Triple cone synchronizer in 2nd
2005 CD008
2005 CD009
Double cone synchronizer in 4th
Triple cone synchronizer in 1st, 2nd, 3rd
I took these figures from the FSM's from the "Service Data & Specs" section of the MT chapter. The transmission of choice for Z drivers replacing their transmission is the CD009 and if you do a little internet shopping you can find them at most shops. Besides having more synchros for the more commonly used gears the CD009 has synchros that aren't as soft as those in other transmissions. "
Old 12-15-14, 02:04 PM
  #438
UpInTheLex
UpInTheLex's Avatar
Good work Estomax. I hadn't heard anyone mention the HOKE shifter setup in these threads yet. This is the most comprehensive thread that I've seen about this topic on CL. Many of the other smaller threads about this topic point to this one, so I'm compiling the info here. My info only pertains to the 1UZ V8 engine in a SC400 and that's where my knowledge stops.
Old 12-17-14, 09:20 AM
  #439
UpInTheLex
UpInTheLex's Avatar
Found another helpful thread to include here where clublexus member finds out the cd009 is to large to fit into the IS300. There are lots of relevant photos.
https://www.clublexus.com/forums/per...sion-swap.html
Old 12-24-14, 09:00 AM
  #440
jkpgt96
jkpgt96's Avatar
How does the cd009 compare in size to the v160? I know it is longer but how does the diameter compare at the bellhousing end?
Old 12-28-14, 08:51 AM
  #441
jkpgt96
jkpgt96's Avatar
How far apart are the holes for the transmission. Cross member on the sc? I am talking about the distance from the holes on one side of the tunnel to the holes on the other side.
Old 12-30-14, 03:55 PM
  #442
UpInTheLex
UpInTheLex's Avatar
I worked on this spreadsheet to verify that 3.26 is the best final drive ratio for the CD009.
As it turns out, the ratios are nearly identical to a V160.
I uploaded a photo of the spreadsheet.
Old 12-31-14, 04:56 AM
  #443
lexuslif3
lexuslif3's Avatar
Estomax could you post up the link to your build thread. Please and thank you.
Old 01-05-15, 03:00 PM
  #444
PseudoK
PseudoK's Avatar
thought I would quote something here, see what people think. from CJMR2T from mr2 forums
The CD0009 is not really any better then the V160, its weaker and only as a .032 taller 1st gear. Overall ratio in 1st gear with the with the V160 and stock SC400 rear end will be 15.001. With the CD0009 and stock rear, it will be 14.874. The Supra setup (V160 with normal TT manual diff (3.133) has an overal 1st gear ratio of 11.989. With the fairly easy to find 2.97 1st gear T56 and the stock SC400 rear end, you end up with a 11.642 overall ratio, so just a tiny bit taller overall 1st gear, and you get double overdrive. Back when I had my supra and did a twin turbo UZ swap, I did use a T56 (Viper trans with 2.66 1st gear) along with a custom Ford 9" IRS rear diff with a 4.33 gear (basically a Ford 9" chunk in a custom housing to make it for independent rear suspension). This gave me 11.51 overall 1st gear and 6th gear overall was 2.165. At 80mph 6th gear, I was taching 22~2300rpm and the car would average 32~33mpg on the highway (pretty damn good for a 3200lb car with a 600hp v8 but running in the low to mid 16:1AFR range while at highway cruise helped quite a bit with the MPG).
Old 01-05-15, 06:33 PM
  #445
UpInTheLex
UpInTheLex's Avatar
He's making a case for the T56. I would honestly rather use a t56 but no one is offering a complete kit package like Collins does for the CD009.
The gearing of the T56 is more well suited to the stock auto/ NA 5 speed final drive gearing in the SC. It does have the bonus of a second overdrive gear. Downside, IMO, is 1st gear is still sort of tall and unless you're making big torque from idle, 1st gear may seem a bit sluggish.
This is why the 3.26 ratio final drive from a GS/SC is a must with the CD009 in the SC. The gearing is so close to a V160 you wouldn't be able to tell a difference. This way, you have 'factory' selected gearing and if you're making power similar to a TT supra, you know the gearing is going to be all good. I look at the CD009 as a V160 replica. It's not as strong, theres a few hoops to jump through, but in the end, you can hardly tell a difference and it will handle the power levels I plan to put through it just fine. All in all, the complete CD009 package will cost $1000 less than just the V160 gearbox. Plus IIRC, I've heard rumors of a rattling sound from the V160 at idle without a dual mass flywheel.
Old 01-06-15, 10:26 AM
  #446
PseudoK
PseudoK's Avatar
So its more a case of rear diff than it being a v8?
So where do I get a 3.26 and is it lsd?
Old 01-06-15, 12:01 PM
  #447
UpInTheLex
UpInTheLex's Avatar
Junkyard from any SC/LS/GS with 5 speed auto. Pretty much any lexus v8 with a 5 speed auto with have the 3.26. No LSD. You'll need to swap the carrier with an LSD carrier of your choice. I have a Cusco RS 1.5 way LSD and really like it.
Old 01-20-15, 05:18 PM
  #448
PseudoK
PseudoK's Avatar
ok so I can find a SC430 diff pretty cheaply. whats the difference going to be in everything, can I expect better gas mileage and cruise speed?
also if I bought a diff like what you have, pretty easy to install? and does it have to be specific to the SC430 in this case?
I would die for gas mileage previously mentioned with the T56.
Old 01-20-15, 06:09 PM
  #449
UpInTheLex
UpInTheLex's Avatar
It puts the gearing into a range suitable for daily driving. Otherwise you're going to be shifting more often and reving high rpm at cruising speed on the freeway.
Yes, you need to get a diff specific to the 'Small Diff' A0xx-series 200mm ring gear differential found in sc, ls, gs, auto turbo mkiv supra, and na supra.
If you got a diff for an automatic turbo mkiv supra, you'd be buying the right thing.
This is just an opinion but I don't think you'll see that gas mileage claims of the t56 without the LS engine attached to it.
Old 03-12-15, 07:48 PM
  #450
PseudoK
PseudoK's Avatar
my kit from collinsadapters specifies notching the bellhousing where the starter is, first time I heard of this, where would I be notching and would a grinder work just fine?
also I fail to see how an engine with bigger displacement and a simple OHV system would get BETTER gas mileage..
Quick Reply: 350Z trans adapter?
