350Z trans adapter?
Old 05-01-12, 08:35 AM
  #31
g-magoo
g-magoo's Avatar
Originally Posted by sc4doubleO
Ok i will shine some light since I'm doing this to mine. 1uz to z33 trans
I'm using the flywheel from a toyota 4 runner 3vz (modded slightly)
Clutch disc: nissan sr20 / 300zx / 350z etc.. all them will fit the input spline
Pressure plate: mr2 turbo
Throw out bearing needs a spacer (seems to release the clutch but i haven't driven the car yet)
You need an adapter to fit the pilot bushing (very simple)
custom transmission cross member (trans mount from a 300zx or 240sx is the easiest)
Drive shaft: you will need a slip yoke from either a 350z or a nissan titan and have a shop either weld it to your oem drive shaft or make a new 1 pc
Shifter assembly sits far back so you will need to cut it and re weld it about 4 inches ( or buy the custom bracket which $200)
Are all these parts the same if adapting a 1JZ/2JZ instead of a 1UZ? What needs to be done to the 4runner flywheel? What are these spacers and adapters for the T.O. bearing and pilot bushing?
Im really interested in this and want to make sure this is something feasible in a weekend before I commit 100%.
Old 05-01-12, 08:56 AM
  #32
ihiryu
ihiryu's Avatar
Reverse lock out requires the original shifter plate which didn't come with the trans I bought. I'm done with the swap and been driving it for a week and I doubt that you can engage reverse after fifth gear. Trans shifts great at any rpms but I am using the "cd009" version. For anyone that is not familiar its the revised version which nissan released in 2006.
I would not use anything from 2005 and earlier just as a precaution.
Gearing is very short with the stock early sc400 differential. I might swap it with a late model sc400/gs400
I'm crusing 50mph at 2k rpms in 6th gear. But it does accelerate very quick.
Very solid trans so far.
Wow, scary!
I had the same problem with my w58 + 3.93 combo, had to move to a 3.26. I think a few other guys moved to the 3.26 also. I don't think the 3.73 would make that much of a difference.
Old 05-01-12, 05:16 PM
  #33
SCott300
SCott300's Avatar
Correct me if I am wrong tho, wouldnt the R154 still be the most cost effective tranny to go with, because it sounds like the 350Z 6speed is still going to be pretty pricey by the time you purchase all the parts to do the swap and then sounds like I would still have to change out the rear on my 92 5-speed
Old 05-01-12, 06:49 PM
  #34
INTIMAZY
INTIMAZY's Avatar
It's not a cheap alternative to a R154, however, it may be a cheap alternative to a V160 (IMHO an upgrade to one as well).
Old 05-08-12, 09:53 PM
  #35
HotcakesIS
HotcakesIS's Avatar
Im going to try this swap next r154 is almost a 2k swap if im going to spend that i will at least shot for the 350z trans. Have any info on that dude that makes that bracket? I live in tampa fl myself and will try to pick that up.
Old 05-08-12, 10:49 PM
  #36
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
Interested in this. Most people don't need the enormous torque-holding or expense of a V160.
Does anyone know what real world horsepower numbers the CD009 is capable of holding reliably?
Old 05-09-12, 01:12 PM
  #37
INTIMAZY
INTIMAZY's Avatar
I wouldn't say any less than the V160. Most have not tested it to its limits but there are several 900rwhp, 1250wrhp and even one guy pushing in the neighborhood of 1800hp (now on a powerglide). They're very solid trannys. There are very few if any power related failures. The only failure I have ever heard of was actually a guy that powershifted his to an early grave after a few years of drags over on the MY350Z forums.
Old 05-09-12, 06:41 PM
  #38
sc4doubleO
sc4doubleO's Avatar
Sound Performance broke the trans when launching their 350z with slicks. They made around 1200hp at the dyno. I doubt anybody here would swap this 6speed instead of an automatic to do real drag racing.
I am only running the stock 1uz but I can tell you this trans feels very solid also shifts as fast as you can at any rpm. I've never driven a 350z before so I was hoping for the best. I will try to get some images together and start a new thread with info that may be important.
Old 06-20-12, 03:37 AM
  #39
racersky
racersky's Avatar
Subscribing to this for future use.
Old 06-20-12, 04:02 AM
  #40
racersky
racersky's Avatar
the company that makes the bracket for the shifter is www.vq35swap.com
Old 06-21-12, 05:57 PM
  #41
smokeytire
smokeytire's Avatar
Has anyone done this to a 2j or will i be the first? I am also wondering if any milling of the bellhousing due to the adapter being in place? ie adpater is x thick so mill x amount off trans to matxh?
Old 07-01-12, 07:13 PM
  #42
SCott300
SCott300's Avatar
With this tranny swap, will I have to change my rear end? I have a 92 SC3 factory 5-speed na-t. Motor is set-up to make 550ish whp but is limited by the weak w58 and fuel (I still need to upgrade my fuel system)
If I need to change my rear, what diff's can I use? Also, what needs to be done to the drive shaft, to make this work?
Thank You in advance
Old 07-02-12, 08:38 PM
  #43
HotcakesIS
HotcakesIS's Avatar
your going to have to use the 350z diff.
Old 07-03-12, 05:24 AM
  #44
INTIMAZY
INTIMAZY's Avatar
Not necessary to use the 350z diff but it would be nice to use because of better spaced gear choices.
Old 07-03-12, 09:17 AM
  #45
SCott300
SCott300's Avatar
What needs to be done to install the 350Z rear? I am assuming that it wont bolt just bolt up in the factory SC3 location, or does it?
Originally Posted by 1UZ240
Ya, I got a question about if you have to change the rear-end to use this adapter plate with a stock SC300 original 5-speed car, (4.27 rear diff ratio) and the answer is no, however the gearing is really close together on these transmissions, I recently did a 350Z transmission swap for a guy with an SC400 and he said the car is alot faster!! I asked him If I could ride along to get a video, and he was cool with it, so hopefully that will come soon.
I personally would like to get a taller rear-end since I do alot of highway driving and want to keep the rpm's down as much as possible. so I would recommend the 98-2000 SC00 differential coupled with the 350Z transmission. that should be a great combination.!!
What is the 98-00 rear gear ratio?
Quick Reply: 350Z trans adapter?
