I can't fill my gas tank on the SC300
Old 03-26-12, 03:33 PM
cudajim
cudajim's Avatar
Default I can't fill my gas tank on the SC300
I have a 2000 SC300 and cannot fill the tank. I can only get small amounts of gas into the tank before the gas pump shuts off. What do I check? It's been getting progressively worse. At first I just thought the wife was incompetent but if I can't fill it I know there's a problem. The car only has 72k miles on it and runs great.
I also need to know where I can buy a service manual.
Old 03-26-12, 03:38 PM
Kalogerus
Kalogerus's Avatar
The reason the pump shuts off is when the gasoline reaches a certain level a circuit gets completed and sends a signal to the pump to stop pumping. I'd say something is clogged up? When you over fill does gas come gushing out? Is your gas reading correct on the cluster? Try filling up with a funnel and see what happens.
SC tanks take about 20.6 gallons of gasoline. Try to use premium and if the capacity is less than that I recommend cleaning the tank.
Old 03-26-12, 05:56 PM
OG Dada
OG Dada's Avatar
No need to buy the service manual. Just call Lexus, they'll send you brand new one for free.
And also, that happened to me once before, the pump kept on shutting off with just $10 pumped in... Although it was a problem with the pump, cause I moved to another pump and it worked fine...
Old 03-26-12, 05:59 PM
g4ebguy90
g4ebguy90's Avatar
Wait what, free service manual?
Old 03-26-12, 06:34 PM
OG Dada
OG Dada's Avatar
Yes, call Lexus up and just register, they'll send you the manual for free.
Old 03-27-12, 08:59 AM
cudajim
cudajim's Avatar
I have already tried several pumps to no avail. I also tried filling it slowly, sticking the nozzle in further and every variation I can think of. There is definitely something wrong, something clogged etc. I really need an answer that makes sense cause I cannot fill it with that all-important expensive gasoline.
As for the manual, what does "call Lexus" mean? Do you have a phone number or web contact?
Old 03-27-12, 09:13 AM
OG Dada
OG Dada's Avatar
Look up their number on their website. They should have a 1800 number on there. Not the dealer near you, it should be Lexus directly.
Tell you what, why don't you remove the false wall in the trunk so you can see your gas tank and let us know what you see. Or take a picof it to make it easier for everyone.
Old 03-27-12, 10:07 AM
gadgetSC
gadgetSC's Avatar
This is for a free Owners Manual......Completely different from a Service Manual.
Old 03-27-12, 10:14 AM
Subjug4tor
Subjug4tor's Avatar
lol just a bit. PM me if you want a .pdf of the service manual, I've got a copy.
Old 03-27-12, 10:43 AM
cudajim
cudajim's Avatar
I removed the panel last night and sure enough there is a gas tank in there. I didn't seen anything that resembled a charcoal canister so I assume it's somewhere else. I'll wait till I get a service manual I suppose.
Old 03-27-12, 11:14 AM
Teal Sc400
Teal Sc400's Avatar
Here a link/process to remove the fuel gauge and look into your tank. Hope it's helpful?
http://soarer.ace.net.au/removal.html
Old 03-27-12, 11:42 AM
cudajim
cudajim's Avatar
I don't think looking into the tank will solve the problem. I'm thinking a vent tube is clogged somewhere.
Old 03-27-12, 07:24 PM
Luxor
Luxor's Avatar
How do gas pumps know when your tank is full? Does it sense pressure?
Old 03-27-12, 07:42 PM
OG Dada
OG Dada's Avatar
Oh damn, I was under the impression the whole time of owners manual!
But yeah I have a PDF of the service/shop manual as well if you want it.
Old 03-28-12, 09:45 AM
cudajim
cudajim's Avatar
So does anybody know if there's a charcoal canister involved with the sc300 gas tank? If so where is it located?
Quick Reply: I can't fill my gas tank on the SC300
