Removing Engine and Trans
Old 09-19-11, 11:14 AM
InLyneTrbo
InLyneTrbo's Avatar
Default Removing Engine and Trans
Just wanted to ask you CL members if there is anything special that needs to be done or anything tricky that might stall me from completing the process of removing my engine and trans.. I'm trying to get it done in one weekend, so anything or any tips will help.
Old 09-19-11, 11:57 AM
Ali SC3
Ali SC3's Avatar
remove the radiator. unbolt the ac compressor from engine, and leave it and the lines in the car. you may get more specific info if you told us whether it is a sc300 or 400.
Old 09-19-11, 01:07 PM
InLyneTrbo
InLyneTrbo's Avatar
oh sorry, '93 sc300 auto. yeah ive already removed the radiator. this car has A/C delete already too. ok thanks any more would be helpful
Old 09-19-11, 03:20 PM
Ali SC3
Ali SC3's Avatar
I don't think there is anything special besides that on the 2j.
Old 09-19-11, 03:29 PM
account2x
account2x's Avatar
unbolt the hood latch
jack up the rear of the vehicle to help get the transmission inside.
Old 09-19-11, 03:56 PM
InLyneTrbo
InLyneTrbo's Avatar
Ok sounds like a plan, thanks
Yup, hood latches were the first thing that i removed since the dampeners had no pressure left in them and the hood kept slamming on top of my head. ill use that advice when getting the trans back in, thanks for that
Old 09-19-11, 05:44 PM
TLDriver
TLDriver's Avatar
you will need beer...
Old 09-19-11, 07:31 PM
InLyneTrbo
InLyneTrbo's Avatar
That's an already given.
Old 09-19-11, 07:57 PM
Vwpride12
Vwpride12's Avatar
Drain your fluids, undo the harness from the ecu and pull it through the firewall. Pull it out with the motor.
Old 09-19-11, 09:43 PM
chingpo05
chingpo05's Avatar
take off the fan clutch to give a lil more room to pull forward and buy an engine leveler.
Old 09-19-11, 10:01 PM
InLyneTrbo
InLyneTrbo's Avatar
I was wondering about the engine harness, thanks for that tip. I've already drained all my fluids as well.
I got the entire fan shroud and surrounding assembly out already. I just picked up a leveler last week due to some other advice similar to yours given to me. I heard that it makes a world of difference with this process
Old 09-20-11, 10:33 AM
InLyneTrbo
InLyneTrbo's Avatar
anyone know where i can print a PDF or word doc of the SC300 service manual?? I found a 2jzge Supra manual which is very similar, but not exactly the same, a lot of differences as well
Old 09-20-11, 01:46 PM
INTIMAZY
INTIMAZY's Avatar
Just don't forget the rear coolant line going to the heater core. I found it easier to undo from the back of the block when the motor is pulled up out of the mount and forward.
Have something handy to block off the fuel line banjo so it doesn't slowly drip while you wait for the motor to go back in.
Good luck and enjoy, it's much easier than on most other cars. Inline motors FTW.
Old 09-21-11, 06:23 AM
Vwpride12
Vwpride12's Avatar
+1 on that fuel line, I lost about 3 gallons of fuel before I realized it wasn't going to stop, I guess because the tank is mounted higher than the line. I clamped the rubber hose before the banjo with a plastic hose clamps. On the return I just had a scrap piece of rubber line with a bolt stuck in it while the motor was out.
Old 09-21-11, 08:20 AM
InLyneTrbo
InLyneTrbo's Avatar
Ok i'll remember this for the coolant line behind the engine, thanks for the tip. Yes, I've never removed an engine before, only worked on forced induction setups on stock blocks and some custom fabbing. I'm hoping to have it out within one day.
Well, this would explain why my garage smells like premium fuel hahaha
Quick Reply: Removing Engine and Trans
