Is it time for a new ECU?
Old 05-04-11, 09:05 PM
MuGGzyx
MuGGzyx's Avatar
Default Is it time for a new ECU?
the same rough idle, stuttering around 1500-2000 RPM etc that 10+ other threads report.
I have now tried:
Fresh plugs and cables
New fuel filter
Unplugged the MAF and issue didn't change.
Jumpered the fuel ECU, no change.
Bought a new coil, swapped out each side in turn and no change, returned new coil
Replaced Engine Coolant Temp sensor
Cleaned AICV
Adjusted TPS with Meter
Replaced Caps/Rotors
checked all plugs, nothing fouled
No vacuum leaks
So I can't think of anything else besides a new/used ECU?
I found one at a local U-Pull it for $40, so that's less than alot of the other things I have tried...
Old 05-05-11, 12:27 PM
tordon
tordon's Avatar
check out my thread.
https://www.clublexus.com/forums/per...-your-ecu.html
has what you have going one..
basicly..
i wouldnt go used unless it has warranty
youll understand why i say that after you see pics.
the computers i think corode on all of them
Old 05-05-11, 02:18 PM
MuGGzyx
MuGGzyx's Avatar
Well even as a troubleshooting step, if I can get a used one for $40. I would hope that even if the used one isn't good, that the symptoms wouldn't be EXACTLY the same, or the odds are against it anyways. I was just reasoning that $40 is a lot cheaper than even one hour of shop time if I were to have it professionally diagnosed.
So are you saying that a bad ECU can actually take down the sensors themselves with it?
supersc30
02-12-17 12:11 PM
tftimm
04-10-14 10:04 AM
LSVIP
21
10-30-13 01:40 PM
KeoCruz
10-06-12 10:07 PM
Dereke
14
07-06-08 01:46 AM
Quick Reply: Is it time for a new ECU?
