Extending the O2 sensor wires, any1?
Old 12-29-10, 04:59 PM
meangreen1
meangreen1's Avatar
Arrow Extending the O2 sensor wires, any1?
For all those that have gone single, I have not noticed any1 shedding light on this area. With the 1jz harness, the wires are not long enough to reach the downpipe. I would like to see what people are doing
Thanks
Old 12-30-10, 07:02 PM
1980's Avatar
Weld in a new bung. or find an aftermarket o2 that is longer. i had one that fit just right then used the wide band for the other. hope that helps
Old 12-31-10, 09:05 AM
SC51
SC51's Avatar
Or you can just extend them its not a big deal its like 3 to 4 wires.
Old 12-31-10, 09:23 AM
turbodremz
turbodremz's Avatar
extending wires on the o2 sensor isnt any different from extending wires on say some audio equipment. Just be sure you use the proper gauge wires, solder and shrink tube them.
Old 12-31-10, 07:15 PM
meangreen1
meangreen1's Avatar
Great, thats the information I was looking for. Now if I can can figure out how to mount it in the aftermarket downpipe. Need input
Old 01-02-11, 08:22 AM
SC51
SC51's Avatar
meangreen1
Does it not just screw into it? Or if you have the flange type you'll have to weld a mount on the DP or just get a different screw in sensor.
Old 01-02-11, 10:21 AM
turbodremz
turbodremz's Avatar
^^Most of the aftermarket DP's have threaded sensor bungs.
If using the stock flange type, they need to have a mount welded on, or pick up a set of Bosch universal threaded type sensors..unless the sensors on the engine are heated type o2's, then you need to find the heated sensors that are threaded.
Old 01-02-11, 11:05 PM
meangreen1
meangreen1's Avatar
Going to see the price to buy a Bosch universal, but I am also needing to get my downpipe modded, so what ever works I guess.
Old 01-03-11, 08:16 AM
Ali SC3
Ali SC3's Avatar
yeah the universal works great. don't overthink it, I used the ol solder and heatshrink method when I did mine. it will even work if you just twist the bare wires together and electrical tape but if you want the connection to last in the engine bay solder and heatshrink it.
Bhogg
13
11-13-17 11:01 AM
fpoljanec
06-08-17 03:07 AM
Cavedog
10-29-15 12:38 PM
garylexus
11-22-14 04:10 PM
Chefao
11-16-13 06:21 PM
Quick Reply: Extending the O2 sensor wires, any1?
