R154 disassembled: Is this normal? (video)
Old 09-17-10, 02:11 PM
JesLet
JesLet's Avatar
Originally Posted by Slade
You should be able to just rotate the gears and slide it back in.
I can't. Also tried to put the shifter back but in won't shift. Something is stuck.
Old 09-17-10, 02:42 PM
stockhatch
stockhatch's Avatar
I agree that you should be able to pop that rod out. It may take a little bit of effort with a screwdriver or something, but it should move. Don't go crazy on it and break something, but its just a shift rod. Unless you see something on the other end of it binding it should move with a little effort.
Old 09-17-10, 08:03 PM
JesLet
JesLet's Avatar
So i did it with a screwdriver in 1.2 seconds . Scratched my head after that.
I really appreciate your help stockhatch
I have another R154 coming for a spare, I'll compare them about that play.
Old 09-18-10, 06:09 AM
stockhatch
stockhatch's Avatar
No prob. Wow, lucky you, picking up multiple r154s
Old 09-18-10, 06:13 AM
JesLet
JesLet's Avatar
Lucky if both are working properly.
Old 09-19-10, 08:09 AM
Slow_Sc3
Slow_Sc3's Avatar
you seriously need to know what your doing when going through a r154. you pulled 5th gear off and moved one of the shifter forks.
Brucelee28
05-27-16 08:50 PM
Hoovey689
08-29-12 05:16 PM
nickt93
IS - 1st Gen (2001-2005)
07-25-12 06:07 PM
sc5sdanny
Florida Lexus Club
24
04-27-11 07:47 PM
onsknht
ES - 5th Gen (2007-2012)
79
01-22-07 05:23 PM
Quick Reply: R154 disassembled: Is this normal? (video)
