sc300 not starting please help me
06-13-10, 05:00 PM
I have a 93 sc300 and its not starting i get the dashboard light when i turn the key but to start the car and i turn the key the dash get black and no check engine light at all. help!!!!!!!!!!!! thanks
06-13-10, 05:46 PM
06-13-10, 08:47 PM
06-13-10, 09:08 PM
06-14-10, 06:04 AM
make sure your battery cables are good, check fuses does not crank? if it does make sure you got fuel and go from there.
06-14-10, 09:04 AM
Quote:
Originally Posted by
mysoarer
yes do all this first. If your getting spark and you havent done the 12v fuel pump mod I would look into it.
06-15-10, 06:22 PM
i jump the starter and the engine turn over but the car did not start. also my radio is not working air and i found a fuse r something like it in the kick panel fuse box burn dnt no what it is . help
06-15-10, 06:49 PM
06-15-10, 11:19 PM
turbopwr
can u post a picture for fuel ecu mod?
06-16-10, 10:38 PM
try bypassing your fuel pump ecu by putting a jumper wire on terminals B+ and Fp under the hood on the diagnostic port
06-16-10, 11:35 PM
06-17-10, 09:10 PM
turbopwr
i wonder where did he get this info. about fuel ecu mod? i fell like not comfortable to do this mod.
12-07-16, 12:28 PM
I have no power on the control circuit to the starter. Does the power come straight from the relay or alternate path?
Corey513
IS - 1st Gen (2001-2005)
06-21-19 09:50 PM
jwynn
Performance & Maintenance
13
06-11-16 09:32 PM
Bfullen
01-23-16 05:48 PM
PMC75
02-08-13 06:30 PM
edgesc01
15
12-29-04 10:34 AM
b ,
box ,
diagnostics ,
fp ,
fuse ,
fuses ,
jump ,
jumping ,
kick ,
panel ,
sc300 ,
starting ,
terminals
