Exhaust Help on 2JZ Turbo SC300
My car should be delivered on Wednesday and it has to go in for exhaust immediately. It had a 3" Apexi single system but they owner kept the muffler so it's straight pipe to mid car. I'd really love to go back to dual setup and I was thinking of just using 2 Magnaflows (used on most of my turbo projects). Do you guys even recommend putting the mufflers in.....or just straight pipe it. I do not want to use the larger canister style mufflers. I want to keep the exterior as stock looking as possible.
About every combination of exhaust is shown here: https://www.clublexus.com/forums/per...st-thread.html
-scott
-scott
Yes, still 2 cutouts on the bumper which is one reason I want to go back to dual tips. I actually don't mind the size of the canisters on your sig picture, but don't want dual monsters on there.
I need to look into good dual outlet muffler and the possibility of running that under the car with just piping back to the bumper.
It has a center resonator, so even when I lay on it at full boost the exhaust doesn't get ridiculous.
I want to see one too. it would have to be angled just right.
Yep....on closer inspection those are definantly monster canisters That's the difference in a good exhaust though. Even with those giants, it's tucked well and doesn't stick out too much. And compared to the 5 gallon bucket also known as the Super Drager on my Supra.....they are still quite small....LOL.
I've been trying to find just an N1 Dual muffler but I don't think you can buy them without a full exhaust. My plans were to split the 2 canisters and run them to each side since they are tiny compared to most canisters.
check out this shop. they have every kind of bend/splitter/connector you could ever want
http://www.mandrelbendingsolutions.c...pes/Categories
sounds like you just need a y pipe in the middle and run each one back.
One step ahead of you brother Couple of locals recommended that exact website. Looks like I'm going to put a 2-1 collector (3" single to dual 3" or maybe 2.5") under the car and run stright pipe to the bumper outlets for the time being and keep searching for my muffler choice (if I deem it too loud)
Little off-topic here, but did you ever find those headlights Jon? I did a quick google search and didn't get too much luck, other than collision websites (which of course wanted 350-400$ a peice). You could always try and refurbish the ones on the car with one of those headlight refinishing kits they have at autozone, they work great if the oxidation is on the outside.
On topic: who needs mufflers?
after seeing the pic of the 240 im not sure the duals on one side would look good on an SC.
