Need some help removing the PS hose from a SC400
Old 01-20-10, 08:17 AM
philliptie
philliptie's Avatar
Default Need some help removing the PS hose from a SC400
Okay so i believe theres two sections to the hose; one thats coming from the ps pump, and then the other, on the rack and pinion. I notice they connect together at the center right under the crank pulley.
Now whats the easiest way to remove both of these pieces? what size wrench should I use? or is there an easier tool instead? Also do they both usually crack?
I know I have a ps leak because ATF fuild is dripping from the front and the lines look real grimy
Thanks for your help!
Old 01-20-10, 10:30 AM
zhillz
zhillz's Avatar
your power steering system is leaking atf? damn...
Old 01-20-10, 11:30 AM
philliptie
philliptie's Avatar
well isnt that what the ps system on a 1uz uses?
Old 01-28-10, 09:01 PM
monsterfac
monsterfac's Avatar
Most toyota's use ATF for powersteering fluid
Old 01-28-10, 09:17 PM
FAT HEAD
FAT HEAD's Avatar
yup we're supposed to use ATF
Old 01-28-10, 10:41 PM
Cwall
Cwall's Avatar
Mine were cracking and leaking. My brother used a DIY hose from Lowe's that he cut down and it's been holding well for 3 months now. Where in Texas are you? I was at pick n pull in San Antonio the other day and they had about 3-4 PS hoses.
Old 01-29-10, 02:07 PM
philliptie
philliptie's Avatar
yea but i really dont want to pull a old hose to use since im sure those are crap already. i need to get the hose remanufactred by a hose shop.
Old 01-29-10, 10:24 PM
Cwall
Cwall's Avatar
I wouldn't suggest a hose I thought was crap. Many of the cars are low mileage, you would be surprised..
Old 01-30-10, 12:46 AM
stevechumo
stevechumo's Avatar
Oh oh..Are you talking about hydraulic fan pump fluid? PS pump on the SC uses standard PS fluid, but not ATF. ATF is red, while the PS pump is dull clear. If you mix them up, you're done.
If the drip is from the front, check the fan pump. It can drip on the PS hose, but that doesn't mean the hose is leaking. Try to spray some break cleaner and wipe it off clean. Then drive for awhile and inspect it again. Also, check the fan pump reservoir and the PS pump reservoir to see if they're low.
Old 01-30-10, 10:34 AM
philliptie
philliptie's Avatar
Are you sure stevechumo? well i gathered that info from this website --> http://www.lexls.com/tutorials/steering/psflush.html
Old 01-30-10, 11:40 PM
stevechumo
stevechumo's Avatar
That's very interesting. If that tutorial website recommends using ATF, then I guess it can be used, maybe as an alternative. However, I use synthetic PS fluid on my SC.
Revived
12
05-26-16 06:50 PM
mistah1jz
03-10-12 12:10 AM
kook
12-06-09 10:57 PM
grindin8o8
07-11-09 01:27 PM
RUDENESS
06-26-04 04:55 PM
Quick Reply: Need some help removing the PS hose from a SC400
