What year did water pump change?
Hello! Did you ever figure this out? I have a 98 SC300 and am about to do the timing belt service, but not sure which one to buy. There is a 10 hole and a 11 hole. Also, I am not sure if I need to go with the OEM or if I can buy the Aisin. I have heard that the Aisin is suppose to be the OEM manufacturer, but also read a couple places where people have had trouble with it. Are some of the water pumps 2 pieces and others just 1?
Thanks,
Michael
Thanks,
Michael
gte & na-t
It will fit, but you have to make it work because the studs on the newer WP are smaller and weaker, it won't let you install the clutch fan because the studs are too small you need longer studs, and EVEN with the longer studs the pattern is different .
Superfast1
13
07-15-15 02:46 AM
