fuel tap/hesitation/ wanttin to die
Old 01-05-10, 11:31 PM
prolifik22
prolifik22's Avatar
Default fuel tap/hesitation/ wanttin to die
well i got a 93 sc400 and it hesitates when givin gas but the rpm's are steady
i did the 12v mod didnt help so i put it back to normal cause the pump was stayin on
i heard u can change the ecu cuz of some signs i was havin as in white smoke on a cold start.. smelly gas... lights stayin on as in like the washer level light and tank is fuel...but it didnt help(how can u check a ecu is good?)
also i hear a tapin sound comin from the fuel rail area.. and u can feel it ... it sounds like valves but i touch the valve cover and u cant feel it but if u touch the fuel rail u can
every since i took off the 12v mod the car wants to die..what might cause this?
basically when the car is parked it kinda studders and when u drive it its hesitant...
im really stumped and wantin to see if any one can help or has had this problem and solved it cuz i see alot of unsolved threads..
lmk if u have any input or advice i cld try out never hurts
btw i gonna relocate the driver harness this week..cuz its been getto rigged
Old 01-06-10, 12:12 PM
prolifik22
prolifik22's Avatar
any input?
Old 01-06-10, 01:22 PM
TLDriver
TLDriver's Avatar
have you checked all the Vaccum lines? because it even sounds like it can be cracked hose or loose.
Old 01-07-10, 12:33 AM
prolifik22
prolifik22's Avatar
yea checked the vaccum lines and all are good... i also cant hear any leaks went as far as usein a car stethoscope... but i found bad ignition rotors..but still cant find out y im hearin tappin from the fuel rail
Bankswood
17
01-22-13 06:32 PM
Remired
07-03-12 08:35 PM
brad11140
SC- 1st Gen (1992-2000)
02-04-11 04:06 PM
lexyroo
14
04-12-07 02:05 PM
TRD_Power
11-04-05 07:46 PM
Quick Reply: fuel tap/hesitation/ wanttin to die
