safc help
safc help
just installed my safc1 on my N/A soarer (jzz31) and for some reason my check engine light stays on and AFL is not reading anything what can it be?
you probably have it set to the wrong mass air flow sensor. 92-95 have a karman vortex sensor while 96-00 have a hotwire sensor.
Also make sure you use the correct colored wires for the corresponding sensors. Make sure you calibrated the throttle correctly with throttle voltage going up as you press the pedal. And also make sure everything is set to zero on the adjustments.
dlamb89
06-13-15 04:22 PM
