Problem with Passenger Window switches
Both switches for the passenger window are not working. Neither switch light works either, y'know the little lights on the switches. I figured it was a fuse, but when I checked the fuse box none of the fuses were out. Any help?
See if there is power coming from the harness were the switches plug into. Use a voltmeter works the best. If you have no power with the key in the on position you may have another issue. If there is no power from the harness into the switch check the harness with the door meets the body of the car. That spot over so many uses cuts the wires and does all these crazy things. Say if you do get power from the harness to the switch replace the switch. Good luck....
bmoon_007
GS - 1st Gen (1993-1997)
08-24-07 11:34 PM
