ECU for manual conversion
Old 08-12-09, 01:28 AM
SC510
SC510's Avatar
Default ECU for manual conversion
ok so i was wondering if u can use the toyota supra MKIV 5spd ecu for a SC300 auto to manual conversion. i know u can use the the ecu from the SC in which u received the transmission, the auto ecu, or the IS300 ecu, but i'm curious as how a 99 SC300 would react. would the check engine light turn on or will out run with no problems?
Old 08-12-09, 10:40 AM
lemmiewink
lemmiewink's Avatar
I believe no CEL will trigger if you use the auto ecu. The SC will behave like it should. You just have to bypass the neutral safety switch, or else you won't be able to even turn on your car.
Old 08-14-09, 07:30 AM
TURBO819
TURBO819's Avatar
I considered all the above but in the end I used what I had which was the 99 SC300 Auto ECU because the IS300 / SUPRA 5 Speed ECU you would need to have the Chip for your transponder reprogramed or get the chip with the ECU. For me this would have been a big time & money lost becuse I knew that an engine swap was in the my near future. With the auto to manual conversion the CEL would come with the AUTO ECU because of the ECU no longer communicates with the Transmission. DR.Tweak make a Transmission Simulator that should work with that auto to manual conversion.
https://www.clublexus.com/forums/per...peed-swap.html
Old 08-14-09, 04:54 PM
lemmiewink
lemmiewink's Avatar
Huh, Didn't know about the CEL.
Thanks for the correction
Old 08-14-09, 05:04 PM
JspecSC3
JspecSC3's Avatar
If you're doing an Auto to 5 Speed swap on a 99 SC you will have a check engine light that you can easily clear. The only way to avoid this problem is if you find the rare 96, 97 SC300 5Speed ECU.
Old 08-14-09, 08:17 PM
TURBO819
TURBO819's Avatar
I don't think that the 96,97 SC300 5 Speed ECU would work with the 98-00 SC300 because of the 2jzge vvti engine.
mikef
10-27-13 03:25 PM
XxPainxX
03-26-12 10:06 AM
Bleak
11-07-11 06:31 AM
Superjatt
SC- 1st Gen (1992-2000)
14
01-21-10 01:03 AM
nismo2trd
05-12-07 01:44 PM
Quick Reply: ECU for manual conversion
