Lower Oil pan re gasket
Can someone post procedure from book on how to re-gasket lower oil pan. From searching I know that according to the book it takes 2.4 hours There is no guide. My bottom engine is covered in oil. Could somone recomend shop in Denver metro area.
quite likely an oil seal on the front. perhaps cam, or crank front main seal- goes out when older or heavily revved from high pressure
if your milage is high, might as well just change oil pump too if you need a clutch or large service. thats actually an engine out job......
