greddy profec b II
greddy profec b II
I would like to know if anyone else on here is running a a greddy profec b II. Im having problem turnig up the boost past 13 on my 1jz I would like thow what others have there set at
well I have been running 16psi for some time now, and I had a intercooler pipe come off I replace the clamp and every since then I can get 16psi back even with the same settings. I have reset the ecu and everything but no matter what I can get past 14 and it drops down to 12 I have changed me setting about 100 times but nothing.
Did you figure this out yet? I recently disconected one of my intercooler clamps and now this is happening also. I can't boost past 13.9 psi and it falls off towards redline. I also have the greddy profec bspec ii
Also, no changes in any setting from 30% to 100 % [set] value.
I have a few ideas on how to trouble shoot, but if anyone else has any input that would be a great deal.
Hopefully, you get it remedied also.
Sounds like a boost leak. Maybe when you took off that one clamp coupling you might have moved around another one. I would go around check out all of your hard pipes and fittings make sure they are nice and snug. Unless like everyone said boost/fuel cut but you would deff know if it is boost/fuel cut because when you hit cut off it is like a sudden brick wall of power loss.
eliteskill
Performance & Maintenance
05-10-10 11:04 AM
LedZepig
10-29-04 02:17 PM
