So Stuck!!
Old 06-12-09, 08:32 AM
SC2JZ300
SC2JZ300's Avatar
Default So Stuck!!
Cant remove the stock downpipe. Retarded *** nut will not come out. Its time to remove the stud that is there and replace it. Options, comments, concerns, all are welcome.
Need help ASAP, im swapping the motor in a couple days.
Also I thought removing the stock y pipe. But the snag I ran into is that once I removed the nuts the studs there were making it impossible to remove. How did people removed it? Ive heard of options in removing the twins....But trying to do less work as possible.
Old 06-12-09, 08:34 AM
Sup2jzgte
Sup2jzgte's Avatar
I had to use a torch
Old 06-12-09, 08:56 AM
2jzlex
2jzlex's Avatar
Try some PB blaster. Give it a gooood soak. Spray it on, let it sit, spray it on, let it sit. If you have room to bang it a couple times that can help also. It isn't uncommon to torch it or just hack it off either. FYI, if you don't ever want that problem again, make sure to use antiseeze when reinstalling anything exhaust side.
Old 06-12-09, 09:00 AM
Sup2jzgte
Sup2jzgte's Avatar
Good point on the antiseeze, ever since my 2 day ordeal with exhaust flange antiseeze goes on EVERYTHING lol.
I tried everything with mine and nothing worked, so I took out the torch and was done with minutes
Old 06-12-09, 09:04 AM
SC2JZ300
SC2JZ300's Avatar
How did you remove the stud? My nut is pretty much not coming off neither does it have any where to grip on. Help!!!
Old 06-12-09, 09:06 AM
Sup2jzgte
Sup2jzgte's Avatar
if its rounded and you cant grab it with anything you have to cut it off. Could you take a picture so we can see what your dealing with?
Old 06-12-09, 09:12 AM
slappy96
slappy96's Avatar
Sears EZ nut worked for me. Even with rounding.
Old 06-12-09, 09:22 AM
SC2JZ300
SC2JZ300's Avatar
Just took these real quick. Pics Up.
SC2JZ300
SC2JZ300's Avatar
Bought the easy outs. Does not work.
Old 06-12-09, 09:26 AM
ICONYQ
ICONYQ's Avatar
I would either get a vice and clamp the hell out of it or I would just grab a cut wheel for the dremel and cut it off.
Old 06-12-09, 09:33 AM
SC2JZ300
SC2JZ300's Avatar
ViceGrip is what I first resort too. But it literally kept wear it down more and more.
If I do use a dremel to cut it off, how do I remove the stud?
Old 06-12-09, 09:38 AM
craaaazzy
craaaazzy's Avatar
try pb blaster first. spray it on the stud as well. if that doesn't work, cut it off then drill out the stud (use a reverse bit as it may just unscrew itself while u drill it).
Old 06-12-09, 09:40 AM
SC2JZ300
SC2JZ300's Avatar
Probably gonna do that. /\/\
Anthony85
Anthony85's Avatar
Dude just hack it off. The nut is already beyond salvageable.
Old 06-12-09, 09:51 AM
Sup2jzgte
Sup2jzgte's Avatar
What I would do is heat up really good with a torch then try the vice grips, if that does not work cut it off.
I when you cut the nuts off the pieces should separate and then you can grab the bolt and unscrew it in most cases
Quick Reply: So Stuck!!
