Another "Clutch recomnendation" thread for my R154
The R154 swap is in progress but I keep going back and forth on the clutch kit. I'm at 310whp right now, eventually going to 400-450whp some day.
I was hellbent on an ACT Xtreme spring 6 puck but it seems a bit overkill.
Aaron at Driftmotion was trying convince me on his Action Stage 3 system with 6 puck. Nice price. Don't know much about Action clutches.
At this time, my hands are in the air with no idea what to do. What's your recommendation?
do not use act extreme pressure plate , its way too stiff and promotes crankwalk
i am at 500 rwhp (maybe more) about 450ish rwhp trq and i use act heavy duty pressure plate and sprung 6puck disk , holds just fine with zero slippage but very streetable and easily slippable into first gear with almost no chatter
I have the extreme pressure plate on the w58 with the 6 puck sprung disk.
If the heavy duty holds the power thats probably a better way to go.
When the car is cold the clutch chatters so bad that I seriously believe it will be the sole reason my w58 blows apart. not to mention my open differential actually sounds like its about to blow up when the chatter occurs, as the chattering makes it "do its magic".
slipping the car from 3k+ rpms is about the only time i dont get chatter.
I used to run the ACT and really like the clutch...I would say run the ACT. I have heard of some bad experiences with the Exedy kits...As for the 6 puck I have heard there is not much slipping into them...its on or off.
this is all based off a 300ZXTT so take it for what you will.
dumdumgreg
SC400 / 300 Classifieds
14
06-19-10 10:22 PM
