Setting the timing on a 1999 SC300??
Old 05-21-09, 03:55 PM
chinhtense
chinhtense's Avatar
Default Setting the timing on a 1999 SC300??
Hey guys,
I searched the forums for setting the timing already, but there were no guides. Just checking to see if any of you had an idea on how to do it. It's a 1999 with VVT-i. I know how to check it, but not sure where to adjust it at. Please let me know.
Thanks,
Chinh
Old 05-21-09, 04:50 PM
HellFish
HellFish's Avatar
if the 99 uses a distributor, the theres is a 12mm bolt holding the dist. to the head. loosen that and shift it around to your hearts content. or until youre at the right timing. you know...
Old 05-21-09, 05:01 PM
chinhtense
chinhtense's Avatar
It doesn't use one. It has an ignitor.
Old 05-22-09, 11:04 AM
HellFish
HellFish's Avatar
so its coil over plug? if so then you cant adjust the timing unless you get into the ECU
Old 05-22-09, 05:20 PM
ucfa4
ucfa4's Avatar
I love 1jz b/c its internally timed.
Old 05-23-09, 01:14 AM
chinhtense
chinhtense's Avatar
Lol....Thanks for the info tula. Found some more websites saying that I cant set the timing unless I mess with the ECU. Guess I'll have to tear back into the front... Car's been down for almost 2 weeks now. Hopefully have it done on Sunday while bbq'in.
ucfa4 - I thought it was the piston rings....I was ready for a motor swap haha.
Uhhhsc300
03-29-13 06:13 PM
bighead222
03-04-12 09:28 PM
Goofaroo
06-13-11 01:52 PM
MrWigggles
10-05-01 11:00 PM
GSXRAWD
06-22-01 10:08 PM
Quick Reply: Setting the timing on a 1999 SC300??
