Does SC300 have any engine reset tool? check engine?
01-26-09, 10:12 AM
Does our cars have any reset or check engine tools? If yes, Where can I buy these. Thanks
01-26-09, 11:30 AM
autozone, pepboys, pretty much any local parts store should carry a scanner where you can reset it on your own...
01-26-09, 12:07 PM
Since I dont know the year of your car you'll have to make sure if its OBD 1 or OBD II.
01-26-09, 12:42 PM
Mine is a 92 sc300. Isn't there like a special or a specific model that is only for our cars??
i know BMW have their own reset/maintenance tool.
01-26-09, 01:54 PM
forget the german engineering stuff... take battery cables off and capeesh
01-26-09, 02:06 PM
Or remove the EFI fuse in the engine bay fuse compartment for 30 seconds and reinstall it back.So you dont have to reset the clock etc....BAM!!
01-27-09, 12:55 PM
but what if you have problems ei engine/and other crazy **** on your dash??? how would you configure then?
01-27-09, 05:08 PM
okay lets start with the right question...
what IS the actual problem with your car and what light are actually on.
check engine light can be turned off by pulling the EFI fuse in the engine bay. if the light comes back on then you can do a diagnostic test to see what codes it pops up.
airbag light can be turned off too. search for the procedure.
theres more but tell us exactly what your car is doing or not doing for that matter so we can help you diagnose this.
sc4001992
Performance & Maintenance
19
08-21-24 04:30 PM
619miller
11-30-15 07:13 PM
Piratse
Maintenance
09-13-13 08:44 PM
PearlLex
12
08-09-04 11:57 PM
johnw
04-08-03 08:12 AM
airbag ,
check ,
efi ,
engine ,
fuse ,
lexus ,
light ,
powered ,
reset ,
resetlexus ,
rest ,
sc300 ,
set ,
tool ,
vbulletin
