coolant lines for turbo
I used the water lines that used to go under the throttle body. Some people cap these off to keep the hot coolant from heating the throttle body, also makes removing the stock setup easier to remove.
One line is from the upper water neck and the other is located on the exhaust side near the firewall.
gadgetSC
gadgetSC
This is what gadget is talking about.... Basically you are reusing the stock lines from the twins. You can tap them like in the picture and run braided lines. Or you could just simply run coolant hose with barb fittings. But at the end of the day you will thank yourself with taking the time to do it right the first time. Good luck.
Patsum
07-27-12 04:29 AM
bryan767
SC- 1st Gen (1992-2000)
04-11-11 11:47 AM
