a little scared, need help (Timing Belt 2JZ-GE)
Old 04-27-08, 07:09 PM
Inspectah
Inspectah's Avatar
Default a little scared, need help (Timing Belt 2JZ-GE)
I have a 97 sc300 with a 2j, but I am not sure if it is a conflict motor. I was going to park the car when it shut off like it ran out of gas. When I try to start it back up it had no compression. After a few tries with a friend I can see the crank turns but the cams dont
I was woundering how bad could this repair be when it comes to having a conflict motor and it breaking at 5mph
Old 04-27-08, 07:16 PM
tritron
tritron's Avatar
maybe you timing belt broke.
Old 04-27-08, 07:32 PM
neurocity
Neu`roc´i`ty
neurocity's Avatar
Crank turns, but cam shafts do not.....Timing belt.
You pulled the cover off right?
~If you broke the timing belt you will be able to lift up on it. Also will be able to take the belt off the cam teeth. There are notches on the cam gears. They should be pointing in the same direction. If they are not i.e.(10:00exh 2:30int) then the cams are off (misaligned)
~If the cam belt is taught (cant lift up on it) and the gears are straight. You could have striped the teeth off the belt, Or cracked the lower drive wheel.
97' 2JZ (non VVti) are non invasive or non interference.
https://www.clublexus.com/forums/sho...ng+belt+damage
Josh S
Josh S's Avatar
You mean an interference engine? The 2jz is a non-interference so if the timing belt broke, no worries. Just align everything and install a new belt if that is in fact the issue.
Good luck.
Old 04-27-08, 08:23 PM
blackops
blackops's Avatar
It's about a one hour job not knowing what you are doing. Toyota made it idiot proof, you can't screw up the timing. Belts cost around $30, and put a new water pump in there too.. $50
Old 04-27-08, 08:36 PM
Inspectah
Inspectah's Avatar
ahh thanx all, got scared cause I read a list that showd all 92 to 97 sc300 where interference motors
SenecaRex
12-31-15 03:55 PM
Vadim540i
SC- 1st Gen (1992-2000)
11-28-10 11:42 AM
my2jz
05-07-10 10:42 AM
sillyboi12
01-11-10 06:57 PM
ckasper
20
06-08-08 08:27 AM
Quick Reply: a little scared, need help (Timing Belt 2JZ-GE)
