Solenoids
Old 02-08-08, 07:21 PM
EpixINC
EpixINC's Avatar
Default Solenoids
Okay i have searched and found a lot of info, but no DIY on how to replace the solenoids in the tranny... i got the infamous flashing OD off light, and when i pulled the code got code 63 which means bad solenoid... but i cant find out where the solenoid is specifically or the procedure for changing it... if anyone can help me out or direct me to the correct location, please respond. thanks in advance....
Old 02-08-08, 07:24 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Just did... moved.
Old 02-08-08, 07:25 PM
EpixINC
EpixINC's Avatar
okay where is it?????
Old 02-09-08, 09:49 AM
EpixINC
EpixINC's Avatar
someone PLEASE HELP ME.
Old 02-09-08, 01:08 PM
aliga
Former Sponsor
aliga's Avatar
you have to drop the trans pan, and the valve body, and then you will see the solenoids.
if you need them, i have them for sale.
Old 02-09-08, 06:03 PM
EpixINC
EpixINC's Avatar
how much aliga. do u have a picture of them inside the vehicle?
or know where i can find a DIY?
Old 02-09-08, 08:38 PM
aliga
Former Sponsor
aliga's Avatar
110 shipped for 3 solenoids,
if you goto supraforums.com and look in the mk3 section you will see a writeup on how to strengthen the tranny, it shows the trans, and what needs to be done
Old 02-09-08, 11:10 PM
jgdynamics
jgdynamics's Avatar
here is a link i saw on SF.. http://supraforums.com/forum/showthread.php?t=267655
but are those accumalators the same as SOLENOIDS? how many miles are on your solenoids aliga? a friend might be needing some also.
Old 02-10-08, 03:36 AM
EpixINC
EpixINC's Avatar
my thoughts exactly... are accumulators the same thing as solenoids? as far as i know, a solenoid is basically an electrical switch designed to pass current at a certain time or interval..... im interested in urs aliga. i need a price for all the solenoids and that control arm with ball joint... im fixing this baby up nice.
Old 02-10-08, 06:17 AM
aliga
Former Sponsor
aliga's Avatar
if you read the article, it mentions disconnecting the electrical connectors, those connectors are attached to the solenoids
Old 02-10-08, 08:14 AM
EpixINC
EpixINC's Avatar
i did read the article.... so is the accumulator on the other side of the electrical connector? so it goes accumulator--->connector----->solenoid.
Old 02-10-08, 01:06 PM
jgdynamics
jgdynamics's Avatar
hmm, and the instructions are about the same for both trans? the sc400 and the mk3 auto trans?
Old 02-10-08, 01:18 PM
aliga
Former Sponsor
aliga's Avatar
yes sir, the trans is very similar
Old 02-10-08, 01:25 PM
Mr.Phreak
Mr.Phreak's Avatar
You shouldn't need to drop the valve body to swap out the Solenoids
Old 02-10-08, 07:41 PM
alpha65
alpha65's Avatar
the best writeup i have came across so far.
http://www.lexusclub.co.uk/lsocautoboxmod.pdf
ill prob tackle this sometime soon.
Alphaman19
Performance
12-14-17 02:00 PM
Bilal01430
06-19-13 02:05 PM
Bottomsout
04-01-07 12:13 AM
adhana2
Maintenance
04-21-05 05:54 PM
Quick Reply: Solenoids
