Coolent recomendations
Old 09-05-07, 12:31 AM
Luke_in_SD
Luke_in_SD's Avatar
Default Coolent recomendations
I was planning on flushing out my coolant and adding a 60/40 mix of coolant and water and a bottle of water wetter.
Is it a good idea to use Toyota red or is any coolant fine?
Old 09-05-07, 03:28 AM
Lexmex
Super Moderator
Lexmex's Avatar
I would stick to Toyota Red or go 100% for the Toyota Pink (which is a mix of water and coolant). I also dump in a bottle of WaterWetter as you mentioned
Old 09-05-07, 07:21 AM
Luke_in_SD
Luke_in_SD's Avatar
ok cause I have regular coolent mixed right now as well and it thought it would be better to stick to one kind of coolent. I live cali and its hot as F*** these last few days.
thanks
Old 09-05-07, 09:35 AM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
The Toyota red coolant is the best. It's less acidic/corrosive than the green. I noticed a lot of people who had their heater core go bad were using green coolant.
Old 09-05-07, 09:37 AM
Luke_in_SD
Luke_in_SD's Avatar
I'm gonna go pick some up soon, thanks all the input guys
Old 09-05-07, 03:52 PM
5spdSC300
5spdSC300's Avatar
Toyota sells pre mixed and concentrated which you will need to add water. Make sure to use distilled water to keep mineral build up out of your cooling system.
6.0PSD
RX - 1st Gen (1999-2003)
03-11-16 07:35 AM
PlotPoint
16
12-13-12 09:34 PM
nthach
Maintenance
02-11-11 10:33 PM
stillfly45
Maintenance
23
01-18-11 07:06 AM
Philly RX
01-08-06 06:33 AM
Quick Reply: Coolent recomendations
