Personal concern: Are lightened flywheels "loud" ??
I've been doing a lot of research both here and at SupraForums in regards to installing a lightweight flywheel (I'll post this at SF too). I really should change the clutch for my W58 this summer, and I may as well upgrade whatever I can while the tranny is out. I'm interested in either the Fidanza or Unorthodox lightweight flywheels (likely to purchase from MVP, where I found them) as well as a SPEC stage 2 or stage 2+ clutch.
Anyway, my concern is that I read some very brief posts about the drivetrain being "loud" or the flywheel being "loud" after the flywheel was installed. Everyone installs both the clutch and flywheel, so there really is no definitive answer as to whether its the new aftermarket clutch, the flywheel, or perhaps both. Some people say absolutely nothing about it being loud, and others only mention it in passing.
The point here is that of course I'd like my engine to perform well and rev quicker, but I don't want to lose much of the silence I have in my car (exhaust aside). Seriously, constant loud whirring or whatever would be real annoying. Anyone have any input? I need to figure out if this is true before I buy everything in a few weeks. Thanks all.
Maintenance Moderator
its more the clutch than the flywheel... any noise will only be when slipping either way...
a sprung full face clutch disk will have less noise than a 6 puck or an unsprung hub... these noises made by the clutch may have a more distinct and louder sound than those on a stock flywheel, but a oe style clutch will negate that...
I have a stock flywheel, my DF chatters a little at idle if I have the clutch pedal completely to the floor, if I relax on the pedal at all the sound goes away.
