fuel pump
It's in the fuel tank. The fuel tank is located between the rear seat and the trunk.
And yes; you can replace it yourself:
1) Pull rear seat out
2) Pull back the cloth cover
3) Remove the circular tin cover
4) Remove the 10mm screws of the fuel tank access plate
5) Disconnect the rubber fuel lines inside the tank
6) Remove the 3 10mm screws that hold the fuel pump hanger
7) Pull the hanger out and unplug the electrical connector and fuel line.
8) Remove the fuel pump
Install in the reverse order.
-scott
-scott
ImWildBill
14
03-21-14 09:50 AM
