AEM cal needed for BL Stg2 kit
Old 04-20-07, 08:20 PM
craaaazzy
craaaazzy's Avatar
Default AEM cal needed for BL Stg2 kit
hey guys,
i need your help with a good AEM base cal file for my BL Stg2 kit. i'd like to start the motor to make sure everything was installed properly, no oil leaks, coolant leak, etc. i'd then have it fine tuned here. please let me know if you'd be able to help.
BL T61
525cc Precision injectors
2.5mm BL headgasket
AEM 3.5 bar
thanks in advance
Old 04-21-07, 04:13 PM
CantSeeMe
CantSeeMe's Avatar
Originally Posted by craaaazzy
hey guys,
BL T61
2.5mm BL headgasket
AEM 3.5 bar
thanks in advance
Im sorry, I dont have a map to share. But ive just starting on the tuning stage of my project too.
Have you tried the base cal in your software yet?
You should take a look over on the AEM forum if you havnt yet. There are some maps posted. I would think theres a map thats at least close , if you have a BL kit? Just Be careful who's map you load though.
http://forum.aempower.com/forum/inde...c,19489.0.html
-Good luck
Old 04-21-07, 04:54 PM
soarer479
soarer479's Avatar
ive got a titan base map for an nat with a little larger turbo and 1000cc injetors and a aem 3.5 bar so you will need to adjust some fuel but the timing and pre cals should be pretty good
1995sc3
05-21-13 04:23 PM
Kybball#1
Performance
44
12-11-11 10:25 PM
superSC3
08-28-09 01:36 PM
skpark70
SC- 1st Gen (1992-2000)
05-05-03 08:04 PM
Quick Reply: AEM cal needed for BL Stg2 kit
