SC400 compression?
Old 02-07-07, 10:36 AM
BrokenPath
BrokenPath's Avatar
Default SC400 compression?
Well, I had my compression checked yesterday by a friend of a friend and he gave me these numbers.
He said the left side is 160 all the way down.
The right side is 160, 160, 60, 190.
I have no clue what these numbers mean but they sound bad because of the horrible difference.
He said I will need a valve adjustment.
My question is.
Do you guys know if that type of ratio is horribly bad?
Will i still be able to run it for a good while before i buy another 1uzfe?
Old 02-07-07, 11:04 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
You have 1 bad cylinder. The on at 60 has la low reading. I think its more than a valve adjustment and more like a piston ring. The engine will run fine. It'll just be down on power. Let me rephrase. I don't recommend leaving it that way for an extended period of time, but for a short period you should be ok.
Old 02-07-07, 11:32 AM
BrokenPath
BrokenPath's Avatar
Do you think you might be able to give me a rough ballpark estimate of how much longer driven daily.
Old 02-07-07, 11:38 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
Impossible to say. There is obviously a problem. ie a fatigued, poor fitting piston ring. The ring could hold where it is for 6 months or it could completely fail tomorrow. No way to be totally sure.
Old 02-07-07, 11:43 AM
BrokenPath
BrokenPath's Avatar
*sighs* Ok thanks a lot.
I just got done replacing the transmission, and i also need a water pump.
Well, looks like i'll be saving up for a 1uzfe.
Old 02-07-07, 03:28 PM
Sc400Red95
Sc400Red95's Avatar
Talk to Aliga He has a 95+ i think 1u. for cheap with trans blah blah blah...
Old 02-07-07, 04:16 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
When you ask an engine question, do it in the engine forum, please
NotJacob
10-10-18 04:45 PM
igobymark
03-25-14 07:07 PM
Sc4es3
02-19-14 11:30 AM
Matt92SC40
09-11-06 06:13 PM
Quick Reply: SC400 compression?
