Formula to Convert Injector Flows, English to Metric?
I'm playing with my Gauge-Tech unit and hope to get a quick answer to this one. I found two articles during a quick search, but they give different answers.
http://autospeed.drive.com.au/cms/A_0102/article.html says to multiply lbs/hr by 10.2 to get cc/minute
http://www.rceng.com/technical.htm says to multiply by 10.5
Which is correct?
Which is correct?
Not sure as I cheat! Here's a calculator that I use, hope it helps...
http://www.witchhunter.com/injectorcalc1.php4
That calculator uses 10.5 and I believe that is correct (6lbs in a gallon of gas X 60 (min in an hour). Now take 3780 (ccs in a gallon) / 360 (lbs/min) and you get 10.5. Ofcourse thats assuming 6lbs in a gallon which is probably not correct and instead is probably like 6.158975654 which puts it at 10.2. Either way, its not making much difference on the injector size.
Also, the weight of gas varies due to octane and the refining process, so its a rough estimate anyway. I'm getting that gas really weighs around 6.25lbs/gallon which puts the correct conversion factor at like 10.1 or so.
