just need help..
Old 10-24-06, 07:17 PM
lemmiewink
lemmiewink's Avatar
Default just need help..
hi,
pretty new here to the forums but im quite stuck on my decision
i am so torn between which engine to put into my sc 1j or 2j.. so i bought both and needa decide which one! keep in mind this is an auto to r154 swap regardless just cant decide between the 2j monster or the high revving (and supposedly funner?) 1jz which my freinds say is less of a headache and more rewarding... goal is pretty modest imo...
near 500 hp..
im lookin for opinions and how easy/hard to tune either engine...
money/power ratio... which has more bang for your buck etc...
thanks
Old 10-24-06, 07:29 PM
Twin Turbo
Twin Turbo's Avatar
Since money is an issue, 1jz should be the answer. But not sure on which is easier to tune, becuase that should be up to the what EMU you are using.
2jz looks better in the engine bay
Old 10-24-06, 08:19 PM
lemmiewink
lemmiewink's Avatar
also are 2jz clutch kits compatible with a 1jz flywheel? or do i need a mk3 one?
Old 10-27-06, 02:27 PM
lemmiewink
lemmiewink's Avatar
?? no one wants to help the noob?? like i said i have 2 engines here and one needs to go away.. please give advice on which to sell and which to keep
Old 10-27-06, 07:16 PM
over40driv
over40driv's Avatar
I am a 400 owner, but I know your very question has been highly debated for a number of years, you may have to be patient for the guy with the good advice to log on. Take a look at some of the other related threads on this section.
Old 10-28-06, 05:38 AM
vipsoarer
vipsoarer's Avatar
clutch compatibility is transmission related. so a 2jz clutch wont work on an r154 and vise versa. for the 154 you need the mk3 clutch reguardless. As for tuning thats all about if you know how to tune and what you are using, piggy-back vs. standalone and if you have tuned a standalone before. the 1j will be easier to swap in IMO
Old 10-28-06, 07:09 AM
Shrummi
Shrummi's Avatar
i'm going through the same dilemma not that i have both engines just trying to figure which one i want more. Leaning towards 1jz, i'll tell you what pick one then sell me the other one.
Old 10-28-06, 10:21 AM
sc1jzgte
sc1jzgte's Avatar
i had the same choice to make, researched for almost 2 years on this descision and realized the 1jz was for me, i think if your goals are less than 650hp then either will do fine, and if money is a concern the 1jz wins. reliability, another tie. rarity, pretty close these days i think but 1jz leaves you with the 1.5jz option which will put it on top here. dont remeber on the 2jz anymore but i have everything oem working, everything. In short i am a completely satisfied 1jz owner, but its all preference
S0ulTuner
SC- 1st Gen (1992-2000)
35
07-31-11 12:58 PM
r331jz
07-04-11 08:57 AM
atekt
02-27-07 07:42 PM
sc3boost
16
11-15-05 07:42 PM
Quick Reply: just need help..
