Turbo with auto tranny question.
I know that with a manual tranny,every time you shift you release the unused air out the BOV,but since in a auto you stay on the gas,so when does the air release?I know that they have to have a BOV and release it some kind of way.Can someone explain how.
I know my terms aren't the correct terms but you all get what i'm saying.
Thanks
Richard
Thanks
Richard
Thanks
Richard
Thanks
Richard
The bov doesnt release when u shift, it releases when u let off the gas. On an auto, it'll be the same thing, or when the car shifts gears.
Shifting involves letting go of the gas for most people.
Not being a smart ***,just saying that i typed the wrong thing last time and cleared up that I knew that it go off when the gas peddle is let go of.
Now a really childish question,can hear the BOV when the auto shifts,or just when you let go off the gas peddle?
Richard
Richard
Chicago Lexus Club Moderator
Richard
Richard
Chris
Thanks
Richard
Thanks
Richard
for auto if you keep hittin the gas it will not release the bov even if it changes gear... unless you let go the gas pedal for some reason...
Originally Posted by soarer479
only blows off when u let off but it shouldnt blow off between shifts in a manual car if you know how to drive .... you lift you lose
but these other guys are right. BOV =bypass/blow off valve. to release unused compressed air in the intake system. as long as the throttle is open, the compressed air is being used. as soon as the throttle closes the bypass valve releases that compressed air. or somthing like that.
Originally Posted by exodus_2
it's worked by the vac. from intake maniford from what i know... so if you let go the gas then the Throttle body closes and bov will release the unused compressed air traped inside ...
Chris
