Want to do Compression Test...Where is Fuel Pump Fuse?
I am going to look at an SC300 for purchase. i want to do a compression test...where is the fuel pump fuse so i can pull it? Also what are good compression numbers?
Straight out of the factory manual, page EG-38, this is the only connection it mentions disconnecting (just got the car myself and haven't done this yet).
Link to big pic: http://www.pichut.org/up/compression.JPG
Numbers:
Compression pressure: 178 psi or more
Minimum pressure: 142 psi
Difference between each cylinder: 14 psi
Numbers:
