Please Help Me Out WIth A Vibration Problem...
Its concerning a vibration from the rear of the car, mostly on the drivers side. At speeds of about 50 mph and more on highways. When I let off the throttle, I feel an intense vibration from the rear of the car. Its more intense right when I get off the throttle. I cant even see out my driver's mirror its so bad.
I recently had the car 4 wheel alligned b/c of new wheels/susp. I also had the front and rear wheels balanced. The only thing I can come up with is the new driveshaft from the conversion from the Lexus to Toyota one . It had to be measured 2 different times before being installed. Also had the same problem with old lexus wheels on the car too!
I just put 19" Axis Wheels on the car. It also has Tein Flex Coilovers. My car is a 94 Lexus SC300 with a 2JZGTE and 6spd comversion. Thank you
Could be your drivshaft needs to be balanced, your u-joints should be good/new if the recently lengethed your driveshaft. It might be a rear carrier berring, or something messed up in your rear end. Any sounds when turing slow or sounds? MAKE SURE ALL THE BOLTS ON YOUR DRIVESHAFT ARE TIGHT!!!!
whats the carrier bearing?? im having a vibration problem also. also i noticed that when take slight turns. im getting a thumping noise when the steering wheel is turned 1/4 of the way. not sure if its related?? possibly i need new steering rack bushings also??
sorry 2JZGTE SC, i didnt want to start a new thread on the same topic
I8ABMR
01-15-08 09:00 AM
