afc and f-cons
afc and f-cons
ok i have the afc which works for now. my question is can you run both the afc and f-con s? i am just wondering because i like the afc, but i prefer the f-con. this setup will be on a na-t
You would not want to run both as the FCON does everything the AFC does and more. The FCON is a much better unit. The only drawbacks are you cannot alter the settings yourself. It needs to be done by an authorised HKS dealer/installer. Saying that though, once installed and set-up properly there really is no need to adjust settings unless you do a performance upgrade.
