(doubt it) Is a mk3 1JZ harness usable?
Old 07-07-05, 05:27 PM
MadMaxxNA
MadMaxxNA's Avatar
Default (doubt it) Is a mk3 1JZ harness usable?
I doubt it, but I figured I would ask. Is the mk3 1JZ harness usable for a SC 1JZ swap? Just figured I'd ask, since I have one sitting here that I could start lengthening. I have a spare 2JZGE (5spd) harness to salvage some of the body connectors from if they are simmilar to the mkiv supra vs the mk3.
Worst case, I'll unload it to a mk3 guy and buy a soarer harness :lol:
James
Old 07-08-05, 10:54 AM
Bean
Bean's Avatar
I dont think its usable... it uses all different chassis harness connectors... i mean you COULD use it but you'd be cutting all the harness connectors off and soldering them directly into your car... which would take a lifetime...
I'd just unload it to a MK3 guy and get a Soarer harness (who knows, maybe one of them needs a JZA70 harness and has the JZZ30 one himself)
Old 07-14-05, 11:51 AM
JJG2005
JJG2005's Avatar
But aren't both the engine side and ECU side connectors different than a Soarer? I almost bought a 1JZ with a bit lower miles, but had to go with mine w/ 60k miles because of the connectors...
Old 07-17-05, 08:46 AM
Bean
Bean's Avatar
I'm not understanding you I dont think
I do know that the Supra has different auxillary boxes (like for fuses and such) and a few other things...
but I think on the SC you wouldnt be swapping those anyhow?
The injectors, map sensor, various other sensors, etc all have the same plugs as far as I know (the important part)
deputy865
SC400 / 300 Classifieds
12-21-16 09:13 AM
Matt300ZXT
07-31-14 07:50 AM
Lokz
12-26-12 08:13 AM
BrownGuy
22
07-17-11 04:46 PM
Quick Reply: (doubt it) Is a mk3 1JZ harness usable?
