93 sc300 5speed clutch/gears
Old 04-19-05, 09:08 AM
SC3005SPD1
SC3005SPD1's Avatar
Default 93 sc300 5speed clutch/gears
question.... when i go from 1st to second, the second feels rough when i drop it down. Does it mean the gear is going to go out?. When the car's been running awhile its not as bad but its still annoying. 3rd 4th n 5th is smooth. Any thoughts?
Old 04-19-05, 09:59 AM
SDSC300
SDSC300's Avatar
changing the oil in the tranny might help a bit.
I like the royal purple syncro max better than the redline mt90
Old 04-19-05, 10:00 AM
OakTwnPnoy
OakTwnPnoy's Avatar
Syncro may be going out.
Old 04-19-05, 10:14 AM
LexusPunk
LexusPunk's Avatar
I have the same problem buddy. Exact same problem...if you find a cure, let me know.
Old 04-19-05, 11:04 AM
SDSC300
SDSC300's Avatar
I've talked to guys that have the IS and they complain about the 1,2, sometimes 3rd feeling notcy
the oil helps but even if it's brand new in some cases it's not perfectly smooth.
Old 04-19-05, 12:18 PM
SupraCoup3
SupraCoup3's Avatar
my last SC w/ 68k on it felt notchy on the 1-2 shift.
I'll tell you how the new one feels in about two weeks.
Old 04-19-05, 01:44 PM
SC3005SPD1
SC3005SPD1's Avatar
if it iz the sync how much does that cost to replace. I just got a full tuneup on the car so my oil is fresh it did help a bit but in order not to feel it i guess it has to circulate and i wont feel it as much. but i had a 89 accord 5spd w/ 150k and it didnt do that at all i started up and went all smooth
Old 04-19-05, 04:57 PM
SDSC300
SDSC300's Avatar
you can't really compare your accord with this car. IMO.
I just replaced my tranny with a used one, it was cheaper than having the bad tranny rebuilt.
Old 04-19-05, 05:25 PM
JspecSC3
JspecSC3's Avatar
Sounds like a Synchro
Old 04-19-05, 06:50 PM
hello1
hello1's Avatar
probably is the syncro...rebuilding it is about 900-1200 dollars, ur better off swaping in a r154, they are easy to find and really strong.
Old 04-20-05, 11:55 AM
SC3005SPD1
SC3005SPD1's Avatar
what is a r154? from which car?
Old 04-22-05, 03:21 PM
SDSC300
SDSC300's Avatar
also you can get a new w58 for under 1400$
Hello1 makes it sound like you pop out the w58 and just swap in the r154, it's not that simple you need other parts.
search on this there is info!
the r154 is from the MKIII pretty much
Old 04-22-05, 05:54 PM
Kaiser
Kaiser's Avatar
Click here to fix this for $20.00
https://www.clublexus.com/forums/sho...ighlight=green
Old 04-23-05, 01:11 PM
SC3005SPD1
SC3005SPD1's Avatar
oh wow great link... im going to definitely do that and see what happens. ALso how would you know if you need a new clutch. I never had one go out on me so i dont know what to look for.
Old 04-23-05, 05:48 PM
/Aerostar\
/Aerostar\'s Avatar
Hey guys, that thread I made will help with LOOSE/SLOPPY shifts, but if you grind into a gear, that problem has nothing to do with the shifter bushing/seat. A grind or really notchy shift is most likely a synchro, you can try putting in some thick stuff like 85w-140, or try GM's Synchromesh, but there is no easy fix for this problem
Quick Reply: 93 sc300 5speed clutch/gears
