Changing Gearbox Fluid
Old 03-13-05, 04:04 PM
newyorksc
newyorksc's Avatar
Default Changing Gearbox Fluid
I was changing my coolant, spark plugs, and transmission fluid today. All went well except for the transmission fluid. I couldn't get that bolt off to fill. Good thing I didn't drain it first.. Anyway.. does anybody have any suggestions? Its the 17mm bolt.. and i'm afraid to strip it. Best thing go to a shop? I sprayed some WD40 on it let it sit for about an hour.. still stuck. My brother recommended that I drive around for a while.. and then get back at it.. Any other ideas? Should I just go to the shop?
Old 03-13-05, 04:10 PM
aliga
Former Sponsor
aliga's Avatar
do you have room to get a pipe over a socket wrench?
Old 03-13-05, 04:39 PM
newyorksc
newyorksc's Avatar
there isnt really much room in that area
i couldn't use a socket wrench without an extension
so i was just using a flat wrench
/Aerostar\
/Aerostar\'s Avatar
Just give her lots and lots and lots of torque. Shes a strong bolt, shes not gonna snap off or strip
Old 03-13-05, 06:21 PM
PJ
PJ's Avatar
Mine was a real pain to get off. A 17mm shallow socket and ratchet should fit over it in that little space almost exactly. May require a little finagling.... but once on, just slide a pipe over the ratchet and pull, it came off pretty easily when i had that pipe on. Larger radius = more torque .
Old 03-13-05, 08:17 PM
PERRYinLA
PERRYinLA's Avatar
If you have the room to safely do so, a torch will help loosen the most stubborn bolt.
Old 03-13-05, 08:59 PM
newyorksc
newyorksc's Avatar
Thanks for all the suggestions.. will definately try them this coming weekend.
NuwenKhanh
06-22-19 06:52 AM
handogg
08-02-17 05:35 PM
Stu
03-29-14 05:23 PM
rtaylor111
10-26-12 07:48 PM
GadgetRick
08-27-11 09:14 PM
Quick Reply: Changing Gearbox Fluid
