2jz-gte sc300 partslist?
i searched and couldn't find a parts list for this swap, i plan on gettin a front clip (5spd) from what i read i need a custom drive shaft anyother custom parts needed?
thanks for the help
thanks for the help
thanks for the help
thanks for the help
you definitely did not search. there are so many members here with 2jz swaps and whatnot.
there is also a guide for it. you're getting a 2jzgte with a 5 speed (aristo clip?)?
MANY parts are needed for the swap.
the motor itself is a basic drop in with the exception of small things such as extending the throttle cable. just takes a lot of work.
the hard part is figuring out and rewire the haress...good luck and SEARCH!!!!!!!!
so i searched and did not find the aristo front clip install, can u help my newb *** out pls
i just wanna learn
i just wanna learn
Do a search on this forums for a guy named phil auldridge. Im doing the same swap right now. 2jz-gte into sc300. He's done it and has an entire manual of how to do it 200+ pages very resourcefull manual if your doing this swap. He lives in Hawaii, and so do I bought the book for 195 thats how much it cost. Alot of other people i know have referenced me to this guy. He knows his stuff. and is very friendly. Will answer all your questions you need. Try it I did and thank god for Phil... Without that manual swap would take 10 times longer.
