car starting weak
car starting weak
i dont know what the problem can be...but whenever i start the car it seems like its barely starting. someone help please!
Basic questions like this can be found in the search box that's up there. ^^
As for the issue, start at the top. Battery. Have it checked or replace it with another one to see if that helps. Then try terminals. Then the starter. Check the voltage when the car is running to make sure the alternator is doing it's job.
Good luck!
Good luck!
Re: car starting weak
CEO
laoboiGS3
03-11-21 04:26 PM
